D-Tek Water Block Question
Blazemore
Anyone know if the TC-4 Rev 2 Waterblock can mount on a socket A using the socket and not motherboard holes? Kind of like the SWIFTECH MCW5002-A WATER BLOCK mounts to the cpu. I have a Epox EP-8RGMI and was looking for a waterblock that would work. Only one I found so far is the SWIFTECH MCW5002-A.
By the way it's built, it doesnt look like it.
To be sure, email dtekcustoms support.
you know, I thought there was a hold down kit, but I seem to be wrong. From my experiance with the same-sized Spir@l block, its too large to fit the tabs, unless you make a pretty elaborate system.
get a danger den socket hold down and then modify it to work with your needs :p
or build one from 1/8in thick aluminum plate and springs if you can :confused:
