What do you all think? I bought the DIR-655 for $90 from Circuit City and the WRT610N just went on sale for $149.99. Considering I had my last router for 8 years I'm not too worried about $60 extra if it's worth it.
Do you think the Dual-Band will ever be worth it? Or should I just stick with the DIR-655?
Thanks
EDIT: I also see that the WRT610N has support for DD-WRT... is that reason enough to spend the extra $60?
From what I've read the DIR-655 seems to get better reviews than the WRT610.
Thanks
