I have a problem with connecting to all the Internet Radio Stations from a website with Windows Media Player. I've tried putting the computer in the DMZ zone, port fowarding different ranges, and disabling the router's firewall. I don't have any software firewall on my computer, Windows firewall is disabled. When I connect the computer straight to the cable modem it works fine so it has to be my D-link router. I've updated it to the latest 2.25 firmware as well. Even adjusted the MTU settings down to 1472, but doesn't work either. Within Windows Media Player I tried to adjust network settings in options to not use UDP and use the browser's proxy settings or auto detect proxy settings, but still no go. I've also tried to check the "connect to the internet" setting in the Player tab within Windows Media Player already.
Other internet radio stations work with my D-Link router, it is just this particular one from this website. I used to use a Linksys WRT54GS Router and didn't have to adjust any firewall settings and just works until it died which I replaced with the D-link DIR-615.
What else could I try?
Thanks!
Thanks!
