Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
yep, you guessed it. wanna put a fan in my sidepanel plexiglass. i've always heard that you have to take some precautions otherwise it'll crack, how do i do it so that it doesn't crack/break/warp? dremel? machineshop? laser? plastic shop?
I use a dremel. I just turn down the speed and start cutting it. If you try it at higher speeds, it will start melting. After I'm done cutting, I file it down and then use sand paper to smooth out the edges.
Tape up the area that you want to cut. Using the fan you wish to use, mark off the screw holes, as well as the fan hole. I would reccomend using a fine toothed hole saw to cut the larger hole. make sure you do it slowly, with minimal pressure. as for the screw holes use a drill bit thats the same size as the shaft of your screws, make sure you do this slowly, and i'd reccomend doing the screw holes first. use a drill press fer this. a little pressure, back off let cool a sec, little pressure, back off let cool some, do this till your through. then you should have nice clean holes.
1 more thing about drilling holes
DO NOT, I repeat NOT start with a small bit and work your way up to size
(like you would in metal)
The moment you enter the hole with a larger bit it will pull itself in, through and most likely crack your plexi
I drill the holes the correct size first time round
and go slooooooooow
