Custom Duality
holli4pirating
Finally I got the modified CADS from MountainMods for my custom Duality. They don't have pics up on the site yet, but it's a new case that's designed to hold 2 mobos and 4 psu's max.
This is the chasis of mine. It's only going to have 2 PSU's and will use the mobo tray from the UFO, not the Twice 7 (so it will have a 120 mm fan on the mobo tray). The actual trays will both be in the middle of the case, so the gaming rig will go upside down to better vent the vid card.
I figured I might as well put some blowholes on the top panel as well, so this is that that will look like. The blowholes are at the back end of the case.
AIIIIIRFLOOOOOOOOOW!!!
Seriously, sweet lookin plans. I'm not big on the 2 cases in one idea but if you're gonna do it, do it right! And you certainly are.
