Current Battery Life Tests Suck
the way i see it, people shouldn't be as picky about the thickness of their laptops. Seriously, whats the matter with having that extra half inch or so for a battery that takes up the entire underside of a laptop. you could get crazy time. I add cells to my current battery from 9 to 15, its amazing what you can get for life... they just need to make it standard. the amount of companies using lithium ion cells should make the cost less!
Oh, so batteries and laptops should just get bigger and heavier as power requirements increase and time goes on? God forbid technology should, you know, improve.
I completely disagree with you. More power along with a reduction in size and weight without compromising the keyboard, trackpad, or display is the ideal goal that notebook manufacturers should be going for, not making them into these giant monstrosities.
A lot of the point of a notebook is a balance between size, weight, and battery life. You get the best of all of those variables and you get a superior portable computer, simple.
Oh, Serpico. I already pretty much said that, just not quite so descriptively. :p
Just make the pcs run Prime95 smallfft with w/e other crap they have running. Then we will see whats actually worst case battery life.
