M a d c o w
- Feb 27, 2006
Hey everyone
Im just curious on how these mounting holes are compatible to other mobos. I currently have the Cuplex XT block with the same set up you see in this picture. Current set up is i have a Socket 478 hooked up to this Cuplex XT and its mounted to the inner mounting hole, as to the other hole what would be compatible to, 775, Lga 775, 939 etc ..
Thanks in advance for the replies
