crt
chris88
ok, i have decided not to get the samsung 152n lcd and just get a crt and put the rest tward a car. now what ctr to get, 17 inch, black. i run at 1024x768.
cheap is good.
also must be flat.
thanks in advanced
i reccomend viewsonic not cheap.
i would check at your local compusa staples etc. sometimes they got some good deals on no name monitors. you only said you wanted 1024x768 so those should suit you fine.
