Crossfire + Physx card possible?
I recently added a GT520 as a dedicated physx card to my system. I realize there are better choice for a card but I got it for nearly free and wanted to give it a shot
I had the amd 10.7 drivers installed and installed the nvidia drivers and then ran the ff1.04 hack and ran fluidmark. It appeared to be working then I noticed in all games only one amd card was working. I go into ccc and crossfire is disabled and I cannot enable it.
Any work arounds for this?
Also how can I get the GT520 to fold in GPU3?
Thanks.
Hey im aware of using amd card for physx with the new mods and what not. Im not sure about hte otherway around but i cant see why not?
you may have to uninstall the AMD drivers and nvidia drivers again(do a clean wipe of all the drivers) boot back into windows install the AMD drivers and do the hack again with the nvidia drivers. AMD drivers are a bit picky about new cards being added so if you had the AMD drivers installed prior to installed the nvidia card it could be causing the issue.
as far as folding goes, it should automatically work, you may want to try using the old gpu3 client instead of the v7 client.. with the old client it should automatically detect the nvidia card and completely ignore the 6950's. otherwise in the v7 client you probably need to mess with the gpu flags to get it to detect the GT 520.
