CPU stuck to heatsink...HELP!
The Null
um...i pulled off the heatsink from my old 3200+ and the chip came with it, it was all unclipped, so no damage was done...but, how do i get the CPU off the heatsink, its stuck on pretty hard.
thanks
Try using a hair dryer or a heat gun to warm up the cpu and heatsink, hopefully that will help to lossen the thermal goo and allow you to remove the cpu from the sink. You could also just put the cpu and sink back into the motherboard and run prime or somthing of that sort to warm up the cpu, then remove the sink. Remember to use a twisting action when removing the sink, that will help to break up the goo.
And don't forget to check for missing pins (if any are missing, hopefully none are).
ok, i dont have a hair dryer or anything (c'mon 16 year old guy living alone, pfft what do i need a hair dryer for?)
i do on the other hand have 2 zippos, an oven and a very very hot hard drive, could i just rest the CPU on my increasingly hot Hard Drive, or could i just rest the heatsink up side down on the stove to warm it up, and at what temp?
Given that both the heat sink and CPU are joined via smooth metal surfaces, you should be able to use a gentle twisting action to seperate the two without much risk of damaging either.
The alternative might be to get some 95% isopropyl alchohol from a chemist and leave them soaking in it overnight. Should disolve the thermal goo.
Soaking it won't work in this case since the exposed surface of the thermal paste is so small.
Whenever I run into a CPU that seems to be permanently fused to the thermal interface material, I use a flathead jewelers screwdriver, push between the CPU/HSF and twist. It doesn't take that much force once you get it in a good spot.
Good luck!
Dental floss.
Yup, dental floss. Run it between the heatsink and CPU. It did the trick for me years ago on an old video card, removing the heatsink from the GPU.
ok
i got the heatsink and cpu off each other, i shoved it in the oven at 50 degrees, then i got dental floss and tried to fit it between the 2 but it didnt work so i tried a knife and that didnt work, but when i was reaching to get the screwdriver i bumped the heatsink and it fell off the table and that got the CPU off, lucky it landed on the side:cool:
