cpu heatsink advise
blarf
Well I'm debating between those:
Noctua nh d14
TR Archon/silver arrow (and possibly HR-02 Macho)
Corsair H100
Which one would you advise?
two of those are heatsinks and one is a liquid system...
obviously im going to recomend the H100
Based on the [H] review, the Macho seems to be a much better choice - similar performance and much cheaper. Do you really need that kind of cooling for the 2500k though - they don't get terribly hot unless you are looking for an extreme overclock. You could easily get by with a smaller and cheaper heatsink - the H100 looks like overkill for that setup.
i can get the H100 for $96 shipped with a little credit i got at a store. should i get it and be done with it?
