CPU Cooler that fits.
stevedave
I want a cpu cooler that will fit in my pc without hitting my NB heat synk. It has to be under or around 50 bucks and doesn't have to be the best cpu cooler on the block. I'll be useing it on a e6550 and only over clocking it to like 2.8.
my.php
my.php
some measurements or at the least motherboard model, would be very much helpful. if your only going for 2.8 then the stock heatsink will be more then adequate considering its free with the CPU.
