johnj189
- Jan 27, 2006
inzane123 said:You might want to ditch the snapshot program as well. Programs to make your desktop prettier ususally come with unwanted presents. Also, you might want to disable utorrent when you are not downloading something.
mohammedtaha said:ok .. for some reason .. you have rundll32.exe running all the time ..
There's something that has been installed that you probably messed up by not restarting or you messed around with msconfig or regedit. I'm not sure what you did but it seems like that might be the problem you're having.
rundll32.exe could also be a worm..
http://www.liutilities.com/products/wintaskspro/processlibrary/rundll32/
so kill the process and see what happens ...
you might also wanna check in msconfig and see where it's running from or check your registry and see if you can spot where it's running from ...
Good luck
johnj189 said:OK... I tracked down this stuff related to the rundll32 process (see pic). I'm not really sure if any of that stuff is suspicious or not.
Edit: I found on neuber.com someone mentioned if it's running non-stop it could be nVidia-related. I do have that nVidia sound/visual stuff running...
mohammedtaha said:remove the drivers and reinstall them ... check if that clears it
