Could Not Connect to Work Server
ByteDown[H]ard
[H]ard DCOTM August 2026
I have been unable to connect to work server for a few days now. I was wondering if there are any problems at this time?? I deleted the directory and d/l the latest beata 5.04 and gave that a try but still no success. It seems to run fine on other machines in the farm.. Not sure what else to try if the work server is not having problems at this time...
I checked Stanford's server status and the server to which your boxen is trying to connect shows "Accept" so I think it should be OK. Try stopping and restarting the console.
yea ive got a few stuck trying to send results back to 171.65.103.151
hopefully they get it back up soon.
If the work server is busy and the assignment server keeps sending you to it that happens.
What should happen is you get sent to a different work server.
Doesn't always happen.
I normal restart and hope it then sends me to a different work server.
Luck.......... :D
