Hi,
XFX nvidia 780i
E8400
Arctic Cooling Freezer 7 pro (775)
OCZ DDR2-800 REaper 1024 MB w/Heatpipe Cooling (2)
Seagate Barracuda 7200.11 750 gb sata II
2x XFX Geoforce 8800GT (SLI)
Asus Xonar D2X PCI
Asus 20x DVD-RW
Nec 3.5 Floppy
3 Case Fans
Using Corsair HX620w - Power Supply - It is SLI Ready (per their site)
I've used a couple sites to gauge how much power I need and came up with just 450w, but I've read other posts where sli set-ups need 750+ minimum. NVidia site is unclear as my set-up seems to be in the extreme category which.
I may also upgrade to a quad core or upgrade to newer 9 series cards and add another hard drive in the future. It looks like GTX or Ultra need the 750 supply per cosairs site, but this seems strange as the GT max wattage is 138 and the gtx is 145. Doesn't seem like enough to warrant a bigger power supply. Is this due to power requirements beyond wattage? Does anyone know if any of the next gen cards will have a similar power requirement as the g92 8800gt thereby making an upgrade feasable without a new power supply?
Thanks
XFX nvidia 780i
E8400
Asus Xonar D2X PCI
Asus 20x DVD-RW
Nec 3.5 Floppy
3 Case Fans
Thanks
