Corsair H50 issues/bracket
i'd contact corsair and see if theres a way to get a new bracket for it, or make your own bracket. that zip ties not going to work. as far as the pump goes make sure you don't have it plugged into the cpu fan header and/or make sure you have the fan controller in the bios turned off. also you may have to set windows to performance mode to make sure it doesn't try to bypass the bios fan control settings if you are forced to use the cpu fan header.
