Corrupt file problem
Marklar
I keep getting corrupt files I first thought it was bcause of a power outage but after I reinstalled windows it works for a month or so and I do virus scan and use ad aware about every other day and ill run chkdsk /r every once in a while and it will always find damaged files i can run it ten times in a row and it will find different damaged files.
What I got is an nf7s v2 with 2 80 gb sata drives in raid 0 with a gig of corsair matched sticks of ram. Iv been told that sata has problems with corruption but what can I do to test the different componets to see if mabey i have bad ram or something.
Also after I did chkdsk tonight it found a few broken files and when it reboot i got the bsod, so I attached a pata drive and removed the sata drives and disabled the raid controler in bios and reset the boot order. So I go to install 2k pro on the pata drive and every thing seems to work fine but after the setup reboots and when windows should start to load it says "Error loading operating system"
I have formated and reinstalled 3 times and even tried xp a few times and it does the same thing.
Any help you can give is much appreciated I have no clue wtf is going on I never had a big problem like this before.
I finally figured out why the drive would not boot.
I had mandrake installed on it a while ago and when I formated it one of the partitions from mandrake was still there fdisk fixed it now i got xp installed and recovery tools running. Woot i was getting worried
