Cannibal Corpse
- Sep 22, 2002
Hey All,
The Thermaltake's BIG Typhoon seems to be choice among most of you guys, but I have some questions:
1 - The Thermalright's XP-90C is made complementally out of copper and its even more expensive than Big Typhoon, why? Is it the Big Typhoon's design that makes it cooler than the competing products, even when they are made of copper?
2 - Can I replace the fan on Big Typhoon? If so, what do you recommend? (Do you recommend some of those UV fans that would go with my DFI LanParty 'Expert' motherboard?)
3 - I am building my DFI nF4-SLI DR 'Expert' and Opteron 146 (CABNE 0530!) and would like to know if Big Typhoon is compatible with it.
Many thanks in advance!
