Copper themed case, and interior components?
Hiyruu
Is there a way to do an overall copper theme?
For the inside, I'd obviously be looking to use components that feature a lot of copper. Does anyone know of any video cards, motherboards, ram, and other components that feature a lot of copper?
What about for the case itself? Are there any ready-made copper themed cases?
Sounds like you're relying too much on already made products. If you want to follow a certain color scheme, I'd research ways of modding the hardware to suit your needs. Motherboards, video cards, etc can all be painted to an extent. Everything else is up to you. Hard drive covers can be taken off, plated with copper, cleared, and put back on.
I've found the one thing I do most is modify the components I need to fit what I want....instead of trying to locate a specific color match.
Copper corrodes also. So it'd be a good idea to clear the copper (if you decide on building your own)
Copper tubing to route all your wires :).
Any of the higher end ASUS boards have copper heatsinks/heatpipes, against a black background.
