Hello!
Currently running a crystal clear case with embedded LED's creating a fiber optic effect throughout the case. It's one of my favorite cases ever. My only issue with it is that it only has one 80mm fan at lower front, and one 80mm fan at center rear. My Coolmax PS has 120mm fan.
Since PC is in the family room, I prefer to keep it as quiet as possible. Running HDD coolers @ 7V and installed Thermaltake fans (w/temp probes) to keep the noise level down unless necessary. Current AthlonXP setup runs average 52C at about 30% fan speed.
I am building up my next rig, Opteron 185, and I'm questioning if there's enough airflow through this box. I'm not planning to o'c... at least, not right away!
I'm wondering if WC'ing would be better? I would be restricted to an 80mm radiator. Would like to incorporate the Thermaltake fans into the WC. VGA=ATI FireGL X3-256 AGP. Not sure if I would replace the factory hsf with a cooling block. Do they make HDD coolers for WC?
Any comments? suggestions? recommended products?
Thanks in advance!
Thanks in advance!
