Cooling capacity?
what kind of cooling capacity am i looking at with the following:
AC Cuplex XT on an FX60
2x Koolance blocks on dual 512 gtx's - HERE
with a BIP X-flow 120.3
Ehiem 1048
6mm/8mm tubing...
Ehiem 1048
6mm/8mm tubing...
Define cooling capacity?
am i going to be seeing some decent temps? alot better than high-end air?
...ive had a the apex ultra kit on an optie 170 and 2x 256mb gtx's and had 38's on the gfx cards and 35 on the cpu
will the small bore/lo-flow system compete?
Thats a pretty restrictive set up u have there /
But with those small lines it well look sweet .
with that pump and roughly 450 watts of heat created with about 250 liters an hour .and a rise of 2.5 meters
Cpu temps full load about 50-55C
Gpu Temps full load about 54-60c
With this pump
http://www.frozencpu.com/ex-pmp-40.html
with 450 watts of heat and roughly 750liters an hour and a rise of 6meters
Cpu temps 39-42C
Gpu temps 41-46C
I didn't use the equations because tube length and other variables are unknown this should be very close to correct.
Since the pump I linked to was a 36month warranty don't worry about the added{stress} of the smaller lines.
