Need a little advice on my cooilng setup adn fan direct... I have a 600T with a front 200mm fan blowing in... two side fans in a window blowing in... two top fans in a window blowing in and one 120mm fan blowing out that has had the factory grill removed. I had thought about making the window fans blow out instead of in to see if it would help any with my temps. It will be kinda of a pain to spin these the other direction because of the way they are mounted but would it be worth the effort? I always thought this case should have a larger rear fan or more rear exhaust fans. Thx for any advice..
