Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Unless something better comes out before sometime early next year when I'll probably be building a system, I'll go with the black Stacker with casters and no window. I love the all-5.25" front (had that on my Codegen 9011 about 4 years already before the Stacker came out). While I'm pretty good with wire management, I don't try to make it "pretty", just usable and efficient.
Yeh no window. The stacker is built for practicality and stability, putting a window would just detract from those two key points. The case is made from 1mm thick industrial strength steel so putting a flimsy plexi glass 'i like EMI' side panel on probably wouldnt be wise heh.
The stacker looks nicer without the window IMO cause. Simplicity is always the better option
Also, a good portion of the stacker is made of a strong mesh (for cooling), but it will also serve to give it a good UFO glow if you light it internally. Besides, I don't want my new DFI SLI board's colors to be seen. I'm doing a Black/Silver Stacker with a bit of blue trim so it matches the room it's going in.
I got the black without the window. Still working on the cables and setup. With so many bays
it took me a couple of days of playing with it to decide were to place my drives. Plan to put a couple of lighted fans and a cathode light on it. It will look cool with all that light glowing out of it.
I just bought the Blue accent Stacker with Window.
Its soo roomy in side.
I only got the window cause I love the blue light my OCZ modstream puts off and I think I want to upgrade my RAM to the New Corsire XL with the readout display.
Still even with or without the window, best damn case you can get.
EATX, ATX, BTX ability allows for years of upgrade potential.
GOOGLE is your friend =) Keyworrd : Blue Coolermaster Stacker
Anyways, I'm too lazy to find you guys a USA link. Just showing you guys there really is a blue & even a red accented case. - g0at
I like it! It's a shame I can't find ANY vendors for those in the US. Good looking case- and it would match with the blue I was planning on putting in it, also.
They are rare cases to find in blue for some reason. I know they arent extinct in the us though, I have seen them before. You just have to look in Froogle. Heres a site that has them, I dont know how well they do business though.
