Coolermaster stacker
nwahs000
Can someone suggest to me a case that is similar to this one, but a little less money?? Thanks in advance. :)
ShaolinDragon said:
No :)
You cant expect something that size to be cheap.
I'm going to have to ditto that. Besides... have you actually SEEN a CS Stacker? It's like the monolith from 2010, you'll need to brace your desk with cinder blocks if you intend to put it on the desk and you'll have to raise your desk about a foot if you plan to put it under (okay, it's not THAT tall, but it is HUGE nonetheless).
Try searching on eBay for "full tower server case". You might eventually get lucky. I managed to pick up a Supermicro 750 there for about $120 about a year ago. Has a lot of stupid features (fans that apparently cool... um... erm... nothing, etc) but was still a well build monster of a case.
If you're looking for dual ATX power supply support (without mods), 11 external bays (or whatever the stacker has), and the nifty cross flow fans, you're going to be spending some cash.
Build your own out of cement board... it'll weigh about the same and you'll never have to worry about shorting out something on the case.
-BellaCroix
