jhatfie
- Mar 19, 2003
I had been running a Thermalright Ultra 90A with my e4300. Oc'd to 3.2ghz at 1.44v would get a hair toasty and peak at 70c via core temp when running Orthos (58c in bios). Decided to try a CoolerMaster Hyper 212 since I grabbed one for $33 at clubit. Outside of having to remove the motherboard, it was a very easy install. Base was very smooth and flat and although it was large, had no problems fitting in my Antec P180. With the cpu at the same OC and voltages, core temp is now reporting a peak load temp of 58-59c, a whopping 12c difference and this is with one fan that is far quieter than the Panaflo I have on my Ultra 90. If I added a second fan I am sure I could drop temps even more. Overall I am very pleased.
