Cooler Master Stacker 830 cross flow fan
prowley
Is the Cooler Master Stacker 830 cross flow fan any good? Better than 2 140mm fans? I can put up to 4 140mm fans in the side panel or (I think) 2 140mm + the crossflow fan. I would like to get rid of the (noisy) Southbridge fan on my evga 680 by ramping up the amount of external air flowing into the case. Any opinions on the best set up here? Perhaps there is a better way to do this?
I was considering these Aerocool 140mm 19.6 dBA fans (I like quiet):
http://www.newegg.com/Product/Product.asp?Item=N82E16835129249
They seem to be pretty good - but I can't find any other 140mm fans for comparison.
E6600, Zalman CNPS9700, 2 gigs Corsair Ballistix DDR2 1000, EVGA 680, EVGA 8800GTX, 2 Western Digital 250gb drives, GameXtreme 700W psu, Cooler Master Stacker 830 case
I have the original stacker with the crossflow fan and think its great. It really helps cool all the components con your motherboard.
