Cooler Master Centurion
i almost bought it, but after owning a lian li, i will never go back. the insides of that cooler master case is cheap steel, like in any 30$ case you will find. i payed the extra 50$ and got a nother lian li... the quality cant be surpassed. the centurion is a nice case for 50$, but a good case makes all the difference. i would look at the praetorian if i were you
lian li's are overpriced, this coolermaster isn't a bad name.
The case has a lot of space, offers some interesting ideas for extra airflow, maybe mounting a fan in the side of the case.
There's no window in the case, which allows you to do some of your own cutting
There's also no dimple or handle in the side, which means you have a FULL side of a case to work with, whether it be adding fans, cutting a full window, half window, custom design.
The only thing I don't like is the fan port with the com ports on the back of the case, looks ugly, and I assume you have a mainboard form for the ports on the back, that has to go too. I like the case, it's sylish on the front, and there is endless possibilities for custom cutting. This is a good modders case, maybe not a great performance case, especially if you do a lot of hardware swapping. Chieftech or Altec's are the best for that.
