Constant Timeouts with WHS
dr_latino999
Start Off:
WHS Running under VM Workstation 6.5.x
2 Cores of a Q6600 @ 3.0
1.5Gb Ram
Onboard NIC #2 for IP35 Pro 10/100/1000
Problem System, Workstation hosting WHS
Windows XPx64
Q6600 @ 3.0
6 Gigs of Ram
Using onboard NIC #1 10/100/1000
This is an odd situation that I only see from my host system when it is talking to the WHS rather than any other system on the network. When on the host system and directed to the network directory for WHS - //WHSVM/Public for example - constant timeouts so that I can not directly send anything from the host to the Server. In the Windows Event Viewer, Event #50 MrxSmb occurs timing out any transfer that was going on to any system off the server, even going to the point that the data stream off the server comes to a dead stop - no hard drive activity at all. This can happen for Word Documents, this can happen for multi-gig .MKV files. I also can not have programs directly save to the server - Word / Excel / RAR / etc or this timeout will occur.
Now here is the kicker: My laptop which runs Windows 7x64, not a problem. The girlfriends computer running Vista Home Premium, no problem. Another virtual system running parallel to the WHS - Windows XPx32 - no problem. What. The. Flip? Any ideas ladies and gents, all the WHS drives are Virtual, a 750 / 500 / 1000 gig.
Btw, I can pull from the Server directly to the host no problem at all using TeraCopy. As well, I can transfer to the Server using the Shared folders on the host and going through RDP on the Server side.
