My rig at home has recently started rebooting itself without warning, behavior typical of a component overheating, or lack of power, etc.. however my voltages and temperatures are looking normal (cpu temp running around 35-40º C, video card a little high but still in the green section at around 55ºC).. When I boot into Windows in Normal startup mode, it'll reboot itself before all of my startup programs have loaded, sometimes even during the XP boot screen, before the login screen. If I select "Diagnostic Startup" from msconfig, I can get it up and running with essential devices and minimal services, but it seems to reboot when I get a few windows open. When I boot up again after a failure reboot, I get a "Windows has just recovered from a serious error" message, the details of which tell me it's either PSU, CPU, RAM, or motherboard (this is the message from the Error Reporting center). My hunch is that it's RAM related, due to the fact that it will run ok with minimal services before it poops out after loading a few programs. Someone else suggested PSU due to the added hard drives (outlined in the specs below), but they've been running for 3 months or so with no problems in the system until recently.
My hardware specs are as follows (as best as I can remember, I'm at work with no access to my home machine):
MSI K8N Neo4 Platinum SLI motherboard
AMD Athlon 64 3200+
1 GB OCZ ddr400
Either 480w or 500w OCZ PSU
1xPCIe BFG GeForce 6600GT
160 GB Western Digital SATA HD (Main drive w/ Windows)
2 x 80GB IDE Hard drives (backup drives, added about 3 months ago)
So, any ideas as to what particular component may be failing or tips as to how to isolate and figure out what component is failing are greatly appreciated. Need any other info? Let me know.
Cheers
AMD Athlon 64 3200+
1 GB OCZ ddr400
Cheers
