Me too. Although it looked terrible.It will work.
For reference I've used the xbox 360 with composite on my 2007WFP.
Haha, you know what though? He said Gamecube. I think RF would be fine w/ that.![]()
RF would be fine on a standard CRT but on an LCD its a whole different story.
Gamecube connected via Component cables support progressive scan (480P) & widescreen with most of the popular games.
But with Composite your stuck with 4:3 aspect (or stretched to fit which wont look right) and 480i resolution. I dont know if you've seen how PC LCD's handle an interlaced signal but it aint pretty.
Composite in itself has video quality issues (dot crawl), the only way Ive seen it look remotely decent is with TV's that have 3D Comb filters built in, but I doubt a 2007WFP (or any PC LCD) has any kind of comb filter installed.
A gamecube SVIDEO cable would look a little better, you're still limited to 480i but at least you wouldn't have to worry about dot crawl artifacts.
