I have an old Cisco 2514 that's been sitting around for over a year after I got it, having never actually been used by me. I wanted to give it someone I know, but I wanted to log in and verify how much memory it has installed and nuke the old config before he receives it.
However, I cannot seem to get in through the console port. Using the default settings of 9600 8,N,1 and flow control set to off, I get nothing as the router boots. Since I never actual got in the router, it could be anything from the port being fried to the default speed for the line having been changed.
I'm hoping it is just something like the latter. Is there a way to reset the config without actually logging in so that I can attempt to connect using the default settings? The config that is on there has no value and I just need to get in to prove that the thing even works. Thanks for any suggestions.
