Hi,
The queston says it all...
I'm about to undertake a project where data volumes are likely to grow quite large. My current mobo doesn't have onboard Raid so I've been looking into controller cards. Please note that this isn't an urgent requirement as the initial size of the data pool will be small. I'm looking to plot a sensible path forward and so budget for it.
My initial investigation leads me to think that the only real value in using a Raid controller vs software Raid is to keep parity load (Raid 5) off the cpu. Seeing as I'm likely to upgrade to a quad core cpu and mobo next year I'm thinking that onboard Raid is the way to go as there'll be plenty of spare cpu capacity to go round.
Is my logic sound or are there other caveats that I'm not aware of?
All advice and guidance welcome
