Im setting up a DHCP server for a LAN Party but Im haveing a bit of a problem. We want to have a semi short lease time on the server so if we need to change something(ie. change DNS server) they will get the new settings relatively quick.
Well for some reason I always thought when you had a lease and the lease was up it would just try to renew it befor it dropped your connection and re-leased your information. And well during a LAN party thats bad. You cant have peoples connections dropping every 5 minutes.
Im running dhcpd3 on a linux box and was just wondering if there was anyway to work around this. Ive been reading everything I can find on google about it and havent found anything.
Ill get back to looking around.
Any help is appreaciated,
--Sean
--Sean
