connecting GPU
McKie
Stupid question, with connecting GPU
GPU requires 2- 6 pin power connections. The Kingwin LZ-1000 has 1 hard wired cable that has a 6 pin and a 6pin +2 that are bridged together. Should I use just the hard wire that has 2 bridged? or should I use 2 of the modular 6 pin connectors to power the card. Or does it really matter ?
If i use the one that has 2- 6 pins that are bridged am i still getting the optimal power to the card? Stupid Noob question I know.
It doesn't matter, but for cable management purposes it would be easier for you to use the single hard-wired cable.
Thanks, that's kind of what i was thinking, but just needed to be sure.
