Computer Troubles
Well lets see I tried to turn on my computer this morning and the surge protector wouldn't turn on. I plugged it into another outlet and still no luck. I then plugged the computer directly into the outlet and it still didn't work. I replaced the power supply and now the computer loads.
It now stops at the No Keyboard Found Screen (Press F1). I press it but of course its not recognizing my keyboard. So i switched the setup from PS2 to USB and still no luck. I then used anothe rkeyboard and still no luck.
SO CLOSE to making the computer work but now i'm having this problem. Would it have anything to do with the motherboard? ;-) i'm sure theres no connection to the motherboard just for the keyboard/mouse
what do you guys think my problem may be?
