Computer shuts off after 5 seconds! Help
Raskal
Motherboard: Gigabyte 8I 865
Problem: A few days ago this computer started turning on and off by itself. (Example: It starts up, no video, 5 seconds elapse, shuts down.).
I first thought a stuck power switch or faulty power supply. I took the motherboard out and disconnected all components so it was just the MB, PSU, CPU, and RAM. (No case)
I can kick start the computer with a paperclip but it still shuts down after 5 seconds. If the powersupply is turned off, and then switched on, the computer starts by itself... but of course shuts down after 5 seconds. An important thing I noticed is the CPU fan does in fact spin up.
I have never had a motherboard die on me so is this what is happening? What other possibilies are there? Tried resetting the CMOS and reseating the CPU/Heatsink.. 1 stick of RAM... multiple power supplies... nothing. The computer worked flawlessly for 2 years and then started having this problem without changing anything.
Please help!
Have you closely inspected the motherboard itself especially the capacitors around the CPU? Kinda sounds like a wear and tear issue.
I had the same issue with a bad BIOS (after a flash attempt failed). PC would start up for a few seconds, wouldn't attempt to POST and then shut down. A new BIOS chip solved the problem.
I had this happen once...Turned out that I didnt have the CPU fan fully seated on the CPU, so it was heating up enough that the motherboard shut off power
This could be so many different issues, lets try and narrow it down.
I suspect motherboard or PSU initially.
Start by resetting the CMOS.
Do this with the power supply disconnected from the mains.
Was the computer dusty after 2 years of use, did you have to clean it much?
What components were really dusty (if any)?
Is anything still dusty?
Can you unplug everything thats not needed to get basic function.
ie remove hard drives, all memory except 1 stick (try other single sticks too in different memory slots).
Unplug all USB devices.
Try to leave just the motherboard, CPU, 1 memory stick and a graphics card.
If the PC now posts you either have a faulty component/connection or the PSU cant cope with everything connected at once.
Thanks for the replies
No components were really dusty. The computer had been opened and cleaned about 3 months ago.
I reset the CMOS and also took out the battery and re-inserted it. I have not tried a new battery but the computer is only a couple years old so this is unlikely.
This computer was really a bare bones system, not for gaming, overclocking, anything so some of the parts were cheap. If I recall the motherboard was about 80 dollars new.
Thanks for the replies but this computer wasn't overclocked and nothing was done to directly cause this to start happening. I have inspected the motherboard and it looks fine visually.
Since I have ruled out the PSU... I'm inclined to next look at the MB. I do not suspect the CPU because the weird part is the computer turns on itself when a power signal is detected by me flipping the switch on the PSU. Remember I just have the PSU MB/CPU, and RAM out of the case on a phone book. No components or power switches from the case.
It could still be a power related issue but I dont wanna harp on too much about it.
My basic line of thinking is that for a PSU to shut itself down, it usually senses an overload on a rail. Any component plugged in can cause this type of shutdown so its difficult to determine what might be the cause without swapping parts out.
The motherboard can also turn the PSU off but given that it powers up immediately the PSU gets power that is suspect too (given you have tried numerous PSU's).
I feel that that the issue might be a faulty component if indeed the motherboard is still operating enough to tell the PSU to shut down.
Its still a bit convoluted.
If you can try some other ram/cpu/graphics card, that will make it easier.
The video is onboard. I just have the basic MB CPU RAM PSU connected at the moment. I will try some other parts tomorrow. In the mean time can someone answer this question...
Why would the motherboard power itself (CPU Fan turns on) when I switch the PSU switch to the ON position. This occurs with multiple PSUs. Remember it is not connected to the case. I can not jump the power switch for about 30 seconds after it turns itself off.
Its clearly a fault condition making the motherboard power up straight away.
What is faulty is what is unknown.
The motherboard is a strong suspect but its not a definitive answer.
look at the capacitors to see if they are leaking/bulged. some motherboards had this problem a while back causing faliure
Look real close to make sure anything isn't shorting out traces or components on your motherboard. I'm thinking a small screw, or a spring, or something weird that might have fallen on your mobo. Like suggested above, check your capacitors -- the tops should not be bulging, nor should they be crusty or leaking anything. If they are, disconnect all components and toss the motherboard (unless you want to deal with Gigabyte on it).
Double check and make sure that your clear CMOS jumper is back on the correct pins. And try booting it with no memory. It won't fully post without memory, but it surely shouldn't shut off.
Also check to see if your board has a CPU fan connector. Some boards monitor fans and shut down at a certain threshold. I had an asus board that did that on me. There were two headers for fans next to the CPU so I just plugged the CPU fan into the closest one. That wasn't the "CPU Fan" header, it was just an extra. After a BIOS flash, they added a feature to instantly power the motherboard down when the fan wasn't spinning. Since I had the fan attached to the wrong header, the board thought the CPU fan wasn't spinning and it instantly shut down every time I powered it up.
My money is on dead/dying motherboard though. Good catch on checking the power switch. Man, that was an expensive lesson when I learned it!
Use a different power supply, make sure nothing is touching under the motherboard that will short the board... and go from there.
Looks like he's already tried multiple power supplies...
Sorry didn't notice that...
Most starting and stopping is caused by a short or a dead motherboard.
Like i said before make sure that whatever you place it on is not shorting the underside of the motherboard.
If you have another PC make sure to test all other parts on it and make sure none of those parts are causing the dead stops.
A few years ago something similar occurred with a friend's PC. We narrowed it down to a bad stick of RAM. Stick was replaced and PC was good to go. Do you have a second stick of RAM that you can try out?
Worth a try.
CM
