Cant' quite figure it out. Does it with Windows XP and Pro, Even on fresh installs of both. I believe it to be a hardware problem, but i cant quite figure out which component is the culprit. its almost like the reset button is pressed. Any suggestions? Also, it seems my RAM is fickle, i need to run it at a higher voltage for it to be stable, could it be the RAM?
