Computer problems.
keoni
I recently took apart the computer I built several years ago to fix a problem with a broken hook for the Northbridge fan and when I reassembled everything with some different cables (I went from rounded cables to flat IDE cables) and routed wires a bit differently to clean up the case I went to start it and I don't get a POST screen and my drives just keep spinning and the HD Light just stays on. My EXOS and all my fans turn on and OTES lights and fans start up but no POST and no booting. My parts are as listed:
Abit IC7 Max 3 mobo
1gig Samsung DDR RAM (2x 512mb in dual channel set up)
ATI 9700 Pro AIW Video Card
Audigy Sound Card
36gig WD Raptor HD (1st gen and is the drive the OS is installed on)
Those are the main parts and I'm stumped. I've built 2 computers, this being the second one, and have never run across this problem. I just hope I didn't break something cause I don't have the money to buy new components (kids cost a lot of money let that be a lesson).
Any help would be greatly appreciated, thanks in advance.
Make sure that your new cables are connected correctly, and re-seat everything. The problem you describe sounds like a video card problem to me, but it could be a cable that has a bad connection, or is simply bad.
That's where I would start.
Ditto that comment - old IDE cables didn't always have the blocked hole/bump on the connector to ensure that they were plugged in the right way around. If you have a plain cable connector, make sure you have it oriented correctly.
I'm willing to bet it's a cable not seated correctly. Been there, done that...
