Hello everybody so I want to know your thoughts about my computer problem.
Here's what happened.
I was coding for Computer Science I and the computer froze... so i restarted and it frozre again when i loaded C++ ... then i restarted again and it froze right after getting into windows.. then i tstarted going to blank screen at Windows XP loading bar... now it won't even get to the loading bar and i reset cmos and removed ram and tried onl yone and now it won't even give me beeps for ram or go into start-up... that's after i removed cmos and replaced... BUT before i did that it was getting to post but not very far sometimes hanging right after or when you enter bios.. now it will run the fans bu tnothign comes on screen and no beeps.. im' gonna amke sure when i took out cmos i didn't disconnect anything but either way it is hanging and im' not sure why.... any thoughts? I'm thinking maybe the motherboard just took a long time to go bad (since i had leaked water on it a few months ago in a failed watercooling experiment and maybe it just is started to corrode/go bad).
Thoughts would be appreciated i NEED this computer! haah.
