Computer losing power, failing to power itself back on until unplugged/replugged.
Eihli
I wasn't exactly sure which subforum this post would belong in, and I know this isn't exactly a troubleshooting forum but I need help.
Two weeks ago my PC randomly started suffering from shutdowns where it was immediately lose power, and then I restarted it... it would cycle on and off every few seconds until I physically removed the power plug from the motherboard and reinserted it.
First I thought it was the PSU, which is a 1000w Mach, and I replaced it with a smaller 600w and still the issue persisted. There was no smoke or any other visible cue which would lead me to suspect that it was a PSU problem.
Then I thought it was the CPU. I have a Q6600 with a Zalman heatsink. I downloaded speed fan and the temperatures were fine, I never saw them go above 55-65c.
Then I thought it was the motherboard. I bought a brand new EP45 and rebuilt my computer, installed my CPU and installed my heatsink, cleaned off all the dust, new case. etc.
When I went to install the operating system, it started happening again...
Then I tried doing it with different sticks of ram, and still... it persists. The only thing I haven't checked is the video card, but that wouldn't cause a system malfunction or a power cycling problem.
Something is overheating and I don't know what it is.
try a different power outlet? :confused:
plug straight into the outlet if you're currently plugged into a powerstrip or surge protector?
You've checked everything else, so try your video card to rule that out as a possibility before we begin assuming it's your power source.
Well it was the video card which is an EVGA GTX 260. My PSU's have internal safety mechanisms where they shut off in the event of either over-heating and over-voltaging.
Both 4x2 molex pins were connected to the card, and it had run fine for 2-3 months, and the fan is still spinning. Anyone know why this is happening all of a sudden? It doesn't appear that the card is defective.
