Computer keeps on restarting and giving errors even when installing XP
BBCMember
This system keeps restarting and giving errors. Even when I was installing XP from the CD, it was installing for a while, but then restarted when there was 19 minutes left. It then tried to resume setup, but then it kept restarting.
Here is the error that it was giving when I tried to boot from the XP CD again to finish the installation:
Line 13 of the INF file \i386\txtsetup.sif is invalid
Setup cannot continue. Press any key to exit.
The "Line" value is always a different number each time.
And here is the blue screen error that would appear when I would be using Ultimate Boot CD for Windows:
driver_IRQL_NOT_LESS_OR_EQUAL
Stop 0X000000D1 (0x0000F188, 0x00000002, 0x00000001, 0xF73C168F)
acpi.sys - Address F73C168F base at F73AD000, DateStamp 41107d27
It's a Sony Vaio Desktop PCV-RSD400CG.
Suggestions?
if your bios will let you, load the failsafe defaults and/or run memtest. check your voltage rails.
