So, yesterday I was playing WoW and my computer started to have abnormal sporadic freezes of 15-30 seconds. I turned off WoW and it completely frozed at Windows XP.
Then I turned off my computer and re-booted it. Now it freezes at "Detecting IDE drives" in BIOS after the memory test. I suspected a hard drive failure. So after a couple of hours later, the computer booted up fine. And I did a disk scan and found ZERO bad sectors and no errors. After some time it started to have sporadic freezing again. This happened when the computer was under load.
What's wrong with my hard drive? Is it about to burn up the more I use it this way? The temps on it were 50C under load. How can it reach this high when it was perfectly fine for the last past weeks?
