The "PowerBoost" used on most Comcast systems now gives uncapped throughput for the first ten megabytes of a connection. Previously, Comcast had experimented with 15s, 20s, and 30s intervals.
If you've got a router with a fast CPU, you'll often see PowerBoost speeds of 33+Mbps, as shown here:
http://www.dslreports.com/archive?zip=&dnsdom=comcast.net&start=Search
Of course, if your router only sustains 20Mbps, that is all you will ever see.
