Hi,
I am finally getting around to build myself a new gaming rig after 3+ years of using an AGP Graphics Card and an old ATA133 HD (LOL?). My pc is quite slow and its time to switch to both PCI-E, SATA and possibly SLI!
Anyways, I need to find the ultimate gaming case. I plan to OC of course nothing too crazy just enough where it will still run stable and I won't have to worry. So with that said I am looking at doing a hybrid type solution. I'd like to get the coolit freezone on my quad core. Of course I heard it doesnt work well so I might wait for the new revision to come out. I'm also looking at the quad-sli freezone cpu cooler. I hope there is enough room for both in the same chassis. On top of that I plan on using fan's inside the case and heatsinks on the video card memory.
Any suggestions for the type of case I should buy? One other question. On the CM description it says: "CM Stacker 832, the newer and improved Stacker series not only is equipped with the highly praised features from its predecessor, but also incorporates the support for the new Raptor X technology."
What does that mean? I plan to purchase the Raptor.
The two cases I am currently interested in is the CM Stacker 832 and the Thermaltake Armor Series VA8000BWS Black Aluminum. I am definitely open for suggestions.
Thanks for the help!
cugine
cugine
