CM Stacker 830 SC?
Beakerz
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119156
Been looking at this for a while. It's a CM Stacker 830, but just... simple. I know there are major issues with this case such as there being not vent holes/mesh on the side or the front for the fans to of any use. Was mainly looking at this case for possible modding options.
But, i am unable to find any information on this. Was hoping some of you guys knew something about it.
Thanks.
Wow, right after i posted i think i found out that it is called an 830K? Still not sure, anyone have any experience with this thing?
there is a vent at the base of the door so air can still get through there trust m e cooler master isnt that dumb
