My first attempt at watercooling, Ive been learning a ton and its been a really fun project
Components
Case: CM 692 advanced
Mobo: Asus p5q Pro turbo
CPU: Q9950 -- Apogee XT
RAM: 2x2gb 1066
GPU: (2) 5870 in crossfire -- (1) mcw80 and swiftech unisink
HDD: OCZ Agility and wd 1tb black for data
PSU: HX-750
Others: (2) mcr220, mcp655, xpsc dual bay reservoir, a bunch of scythe fans
Display: (3) Dell p190 in eyeinfinity
My original plan for my new 692
Just got the case, bottom rad is instaleld but still on air for now, tons of stuff needed
CPU plumbed!
XPSC Dual Bay res
Tubing route, for now
Bottom radiator has been installed for a while just waiting for the rest of my heatsink to come.
GPU now under water and loop update
A pic of the top
2nd 5870!
Just moved into a new place, it had this little nook that im going to turn into my pc area
Just slapped some wood together for a makeshift desk
(3) Dell P190s for eyeinfinity!
Finished building the desk, Its a bit ghetto but all i had was a tablesaw and drill so
Hooking up my x-540 and trying to do some cable management
3 monitors, surround sound, wired keyboard/mouse, cablemodem and router, everything for the pc
and you thought case cable management was tough, right here Im about to kill myself
Stealthed out power strip nucka
Where I gave up, cables need a lot more work. youll notice I cant decide between portrait or landscape
So thats pretty much it as of today. besides dialing in my cable managment and messing with the speaker config Im pretty much done on everything but the actual pc, which I still have plans for
When I put my 2nd 5870 under water I plan on rerouting my loop like this
still to come:
mdpc sleeving should be here soon
changing my watercooling: rerouting like I said above, ditching the xpsc res for an internal one above a T which should help improve my flow rate a ton, installing a fill port, Picking up some scythe GTs for the rads, and probably and aftermarket sound card
phew
Components
RAM: 2x2gb 1066
PSU: HX-750
CPU plumbed!
XPSC Dual Bay res
A pic of the top
2nd 5870!
still to come:
phew
