Client question
Varroa
Hi Guys, when I am running folding@home as a client on a winXP machine, how can I tell what it is doing? When I used the GUI version I could see the size and progress of the work on a fold but now I have no idea what it is doing. Any help would be appreciated, thanks.
You can also just look at the log file in the folding directory with notepad.
There is also another sweet little "just monitoring" utility called FahMon.
Also another utility that I use, but is not supported anymore is KDFold
There is also KDFold, though it's not supported anymore.... you might still be able to find a copy of it somewhere (I have a zip file of it if you'd like to try it).... it's free also...
Keep on Folding!!
