click.hardforum.com down?
  • Thread starter Deleted member 88227
  • Start date
Status
Not open for further replies.
D
Guest
Seems almost any link I click on the forums times out. If I copy/paste the link into the browser, it works fine. What's the deal?
I've been all over the board this morning without a hitch which suggests it must be on your end.
sounds like something on your end is blocking click.hardforum.com, if you're not at work or you've not got anything that could block it try a dns flush and see if it helps
Status
