I work as tech support for the residence hall I live in, and that means I have to provide support for 550 residents. Having to go to each person that calls and clean out all of the spyware and viruses is getting rather tiring, so I'm looking for an automated solution.
What I've come up with, is a BartPE CD that will work as an either/or solution:
1.) If the computer has boot-off-cd support in the bios turned on, it will boot into the BartPE environment and run an automated virus scan and spyware scan all, drop a .cmd file in the start-up folder in start menu of all users that will run all of the blaster/sasser/etc MS patches (due to liability I can't do SP2, long story) then delete itself (which I will VERY THOROUGHLY test before actually releasing a CD), and pop up a web page showing how to turn on the windows firewall.
2.) If the computer doesn't have boot-off-cd turned on, it will auto-run a .cmd file that will do basically the same thing, just from Windows. This probably won't work as well due to protected files and such, but, eh, it's something.
The problem is, I'm not sure if command line spyware scanners even exist. I see plenty of corporate ones, but none that are CLI. For virus scan it's simple, McAfee's CLI scanner that's freeware too, but I haven't found any spyware ones. Anyone have any ideas?
