Cleaning drivers
Mayhs
i am acting like a total n00b atm.....so can u people help me plz?
ive downloaded the driver cleaner now what do i do? which filter should i clean with?
thnx...
should i driver clean all the ones mentioned?
Edit: i want to keep my oc profiles
I'm unsure where these profiles are kept however I think the 'ATI CCC' filter (unsure if that's the actual name) would delete it. Just uninstall it and use the other filters and it should be ok (you can remember the OC'd speds anyway right?)
yeh...so uninstall through add/remove programmes then use driver cleaner and clean the ati and other things then install new drivers?
AFAIK there should be 3 things: ATI Catalyst Control Centre, ATI Display Drivers, ATI Software Uninstall Utility. I also uninstall in add/remove programs in that order.
tornadotsunamilife said:
<Insert Sherlock Holme's quote> :D
Then you mustn't have any of them installed
lol :p
so how am i playing games if i dont have any installed?
yeh it could be something along those lines...i think my friend wiped my driver by accident whilst he was tinkering with my computer...but if i was using the windows driver would i still be able to use ati tray tool and ati tool (im using them atm)
THNX for al ur help people....i was running no driver lol...and now ive installed 5.13...thnx :)
